1993 Toyota Landcruiser 1993 LandCruiser High Idle
1993 TOYOTA LANDCRUISER
185,000 MILES • 6 CYL • AWD • AUTOMATIC
STONEST
My landcruiser idles ok 6-800rpm when the weather is in the 50s or below. Once the warm weather hits (it's in the 70s today) the car idles at 2200 rpm. It starts right up. Idle drops to 1100 when i put it in gear. I replaced both oxygen sensors last fall when check engine light came on. Any idea's where the problem may be? Vacuum hoses are fine.
Thanks.
Apr 1, 2010 at 8:40 AM
Hi Stonest, Welcome to 2carpros and TY for the donation
Clean out the idle air control valve and test the following throttle position sensor, coolant temperature sensor and mass airflow sensor
Apr 3, 2010 at 7:02 AM
