1993 Toyota Landcruiser
1993 TOYOTA LANDCRUISER
115,000 MILES • 6 CYL • AWD • AUTOMATIC
GENE VOGT
is the Landcruiser front end set up the same as my 1985 toyota pickup? The entire front end pivots on a couple of large ball joints directly behind the brake assembly. The 85 pickup has a square fitting on the top of the ball joint and you just unscrew it and inject chassis lube-- is the Landcruiser set up the same way or are the ball joints lubricated with gear oil from the differential?
Nov 10, 2009 at 1:49 AM
  • 31,937 POSTS
Hi there,
The swivel hubs are part packed with Molly grease there is a seal in the axle tube that prevents diff oil from entering the swivel hub, if oil dose get in the grease will dilute and leak out past the hub seal, this is only a grease seal and it wont hold oil, if you have oil)grease leaking from the swivel hub seal, the inner axle tube seal is leaking and needs replacing, don't think the later cruisers have this square access plug, you will have to look and see, if it dose you can add grease, but if it is leaking, you will need to fix this correctly.
mark (mhpautos)
Nov 10, 2009 at 8:48 AM
