1991 Toyota Landcruiser oil pan
HAPAINBAJA
  • 10 POSTS
Engine Mechanical problem
1991 Toyota Landcruiser 6 cyl All Wheel Drive Automatic
HOW TO DROP AN OIL PAN , SO I CAN CHANGE AN OIL PUMP .. HAVING A MESS ON HOW TO GET THE OIL PAN OUT OF THE WAY ..
May 5, 2010 at 12:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you will most likely need to remove the engine mount bolts so you can jack up the tranny and engine assembly to give room for the pan to ddrop out.
May 5, 2010 at 2:00 PM
HAPAINBAJA
  • 10 POSTS
OK THANKS , A LOT ,, GOD BLESS
May 5, 2010 at 2:08 PM
