1991 Toyota Landcruiser
HAPAINBAJA
  • 1991 TOYOTA LANDCRUISER
Engine Mechanical problem
1991 Toyota Landcruiser 6 cyl All Wheel Drive Automatic
i`m changing an oil pump, I took off all the bolts, now how dose the pan down, so it out of the way to see the oil pump.
Wednesday, May 5th, 2010 AT 7:22 PM
  • 31,937 POSTS
Hi there,
These sumps are chemically bonded and are very tough to remove, there is a special chisel used that breaks the bond and the sump can be carefully removed if you use a screw driver you will damage the sump and this must be avoided.
Mark (mhpautos)
Wednesday, May 5th, 2010 AT 7:26 PM
HAPAINBAJA
  • 10 POSTS
THANK YOU. SO MUCH. BUT THE OIL PAN IS OFF THE MOTOR, BUT WILL NOT DROP OUT OF THE WAY, IT HAS 2 BIG BARS IN THE WAY, I THINK ONE IS A TIE ROD, AND THE OTHER IS SOME BAR NOT SURE WHAT THAT IS. CAN YOU HELP.
Wednesday, May 5th, 2010 AT 7:37 PM
  • 31,937 POSTS
OK, sorry, my mistake,
If you have the car on chassis stands and let the suspension hang down there should be enough clearance to remove the sump.
Mark (mhpautos)
Wednesday, May 5th, 2010 AT 8:02 PM
HAPAINBAJA
  • 10 POSTS
JACK STAND, WE DO NOT HAVE. SO ITS OK TO JACK UP THE FRONT OF THE CAR WOULD IT BE HIGH WITH TIRES OFF THE GROUND. WOULD THAT WORK.
Wednesday, May 5th, 2010 AT 8:17 PM
  • 31,937 POSTS
Never work under a car with out stand if jacked up, go get some stands, if the car slips or the jack leaks pressure you will be crushed.
Mark (mhpautos)
Wednesday, May 5th, 2010 AT 8:30 PM
HAPAINBAJA
  • 10 POSTS
THANK YOU, BUT IF WE GET THE TIRES OFF THE GROUNDS, IT WILL WORK. I`M IN BAJA AT A SMALL ORPHANAGE, JACK STAND WOULD BE HARD TO FIND. WILL PUT SOMETHING UNDER TO KEEP IT UP. BUT IT WILL WORK, SORRY FOR NOT DONATE $$ BUT WE HAVE NONE. NO FOOD, CLOTHS FOR THE KIDS, SHOES. BUT THAT ANOTHER STORY, GOD BLESS YOU FOR HELPING, IF YOU LIKE WOULD LIKE TO KEEP IN TOUCH.
Wednesday, May 5th, 2010 AT 8:40 PM
  • 31,937 POSTS
Just make sure that the car is safe and it won't move, that is the important thing,
Good luck, and thank you for using 2carpros.
Mark (mhpautos) Australia.
Wednesday, May 5th, 2010 AT 10:22 PM
AMBOTANNE
I have the same problem but thanks to this forum.
I really learned a lot since I am not so good at checking and doing things on my own.
Friday, June 4th, 2010 AT 8:16 AM
  • 31,937 POSTS
Did you get your sump off OK?
Mark (mhpautos)
Friday, June 4th, 2010 AT 9:02 AM
