1982 Toyota Landcruiser Steering Problem
1982 TOYOTA LANDCRUISER
36,500 MILES • 6 CYL • 4WD • MANUAL
CRUISER
Difficult to turn the wheel to the left at lower speeds.
I've replaced the Power Steering Pump and High pressure hose.
Any help would be much appreciated!
Jul 30, 2008 at 2:49 PM
KLSHIEL
  • CAR REPAIR CONTRIBUTOR
  • 163 POSTS
The power steering pump provides power to the gear box. If the pump is providing power as it should and no valves are getting stuck the gear box may be bad
Jul 30, 2008 at 3:17 PM
CRUISER
How and where do I check the valves to see if they are stuck?
This was one cause of the problem that a friend mentioned.
Jul 30, 2008 at 3:51 PM
KLSHIEL
  • 163 POSTS
One thing I can think of that would test to see if it is a valve issue or the gear box itself is remove the hydralic lines from the gear box. You will need to figure out a way to get the fluid that is pumped out to the gear box back to the resivior. If when you turn the wheel it is still harder to turn the wheel one way or the other then it is the valves and not the gear box. If it is easy to turn both ways then you will need a gear box.
Jul 31, 2008 at 1:37 PM
CRUISER
Is there a way to clear the valves without replacing or getting the steering box rebuilt. I am under the impression that the valves, themselves cant be fixed without removing the steering box and having it rebuilt.
Jul 31, 2008 at 3:46 PM
KLSHIEL
  • 163 POSTS
I'm not familiar with your particular vehicle, but if the valves are in the gear box then the box will have to be rebuilt to change them. I have never heard of a method of getting the valves cleaned up by themselves.
Jul 31, 2008 at 4:04 PM
LUNENBURGER
  • 14 POSTS
great info thanks
Aug 22, 2008 at 9:41 PM
