Brakes problem
1978 Toyota Landcruiser 6 cyl Four Wheel Drive Manual 200K + miles
Sirs; Two stage master cylinder won't bleed out. I have a tool from napa but still won't remove all air. Do I need a pump? I have read I need to bench bleed, but is that necessary, what is the difference? I have pumped about a gal. of fluid already. Thanks, Rick
Sep 3, 2009 at 5:08 AM
