1976 Toyota Landcruiser starting
1976 TOYOTA LANDCRUISER
139,000 MILES • 6 CYL • 4WD • MANUAL
BMARR
truck wont start no lights dead tried jumping got some lights but nothing after turning key lost lights
Dec 29, 2007 at 6:46 AM
Test the battery might not have enough cranking amps to the starter to engage the engine. You need to double check all connections make sure its clean and tight then comeback. Simple loose connection can do this kind of stuffs.
Dec 29, 2007 at 6:59 AM
