2006 Toyota Highlander Oil Filter
GSH
I don't do much work on cars anymore. They've gotten way to complex and often require special tools. However I still try to change my own oil and do limited other low level maintanance. I just purchased a 2006 Toyota Highlander, V-6 (NOT the Hybrid) and I can't even find the oil filter, much less change it. Can anyone tell me where it is on the engine? I guess that I will probably have to give up even this simple task!
GSH
Jan 27, 2007 at 6:44 AM
  • 75,988 POSTS
[quote:9a51f5613f="GSH"]I don't do much work on cars anymore. They've gotten way to complex and often require special tools. However I still try to change my own oil and do limited other low level maintanance. I just purchased a 2006 Toyota Highlander, V-6 (NOT the Hybrid) and I can't even find the oil filter, much less change it. Can anyone tell me where it is on the engine? I guess that I will probably have to give up even this simple task!
GSH[/quote:9a51f5613f]
Its on the drivers side of the engine block at center. Don't feel bad-me too on a 93 bravada its right in front of my face near the air cleaner assy. here I am looking underneath damn I when bananas.
Jan 27, 2007 at 9:33 AM
Suggested Repair
Look for the oil filter on the driver's side of the engine block, near the center.
Conversation Summary
The owner of a 2006 Toyota Highlander V6 (not hybrid) could not find the oil filter for an oil change. An expert said it is on the driver's side of the engine block at the center.
