2004 Toyota Highlander Steering Shaft
SANDY21
Toyota Highlander 04 4wh drive 6cyl
Had steering shaft assembly replaced. Was told work only involved the sterring wheel and that an allignment was not needed. Is this true?
What exactly is involved in a sterring shaft assembly repair/replacement?
Jun 12, 2007 at 1:03 PM
LOSTINMARS
  • 222 POSTS
unless the person doing it is damn near perfect i would have an alignment done afterwards. also if its not put back on in the correct position the air bag cable in the steering wheel can break when the steering wheel is turned lock to lock.
Nov 3, 2007 at 6:50 PM
Suggested Repair
Have a wheel alignment performed after steering shaft assembly replacement unless installation was exact. Confirm the shaft and steering wheel are indexed correctly so the airbag clock-spring cable is not damaged when the wheel is turned lock to lock.
Conversation Summary
The owner of a 2004 Toyota Highlander had the steering shaft assembly replaced and was told the work only involved the steering wheel and that an alignment was unnecessary. The expert recommended an alignment afterward unless the installer was extremely precise, and warned that incorrect positioning can break the airbag cable when the wheel is turned fully in either direction.
