2006 Toyota Highlander power vwindow
55,000 MILES • 6 CYL • 2WD • AUTOMATIC
GCOUGIE
My rear window keeps falling of the trac and toyato dealer has put it back on twice. They suggest changing the rubber seal around the window and replacing the regulator, sounds like they are just guessing, any ideas?
thanks jerry
Aug 22, 2009 at 12:12 PM
KHLOW2008
  • 41,812 POSTS
Hi Jerry,
Replacing the runchannels would be the first thing to do. They are usually the cause of door glass running out of position.
You can try some silicone lubricant onto the runchannels to see if the problem is resolved.
Aug 24, 2009 at 4:13 AM
GCOUGIE
[quote:c304f19389="KHLow2008"]Hi Jerry,
You can try some silicone lubricant onto the runchannels to see if the problem is resolved.[/quote:c304f19389]
thank you
Aug 24, 2009 at 4:51 AM
KHLOW2008
  • 41,812 POSTS
You are welcomed.
Silicone is only a temporary measure but if you apply it once in a while, it is going to prolong the life of the motor and runchannel. However if the runchannels have hardened, they would have to be replaced.
Aug 25, 2009 at 1:30 AM
