2005 Toyota Highlander UPHILL POWER
LOPAKABOB
Engine Performance problem
2005 Toyota Highlander 4 cyl Four Wheel Drive 140000 miles
I just replaced the sparks and airfilter and still lacking power asending hills. any suggestions?
Apr 6, 2010 at 11:40 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 6, 2010 at 5:01 PM
