2004 Toyota Highlander Washer Pump
2004 TOYOTA HIGHLANDER
COOL_JEN157
2004 Toyota Highlander Four Wheel Drive Automatic
The front washer pump is not working but the rear is. My question is what is the best way to access the pump and replace/repair it?
Jun 5, 2008 at 9:26 AM
  • 31,937 POSTS
Hi there,
The pump should be located in the washer reservoir. if you remove the reservoir it will be easily removed. these pumps are a sealed unit and will not be repairable.
mark (mhpautos)
Jun 5, 2008 at 12:14 PM
