I left the key on in my car, if i jump it how long will it have to run to charge the battery back up?
Nov 6, 2008 at 10:34 AM
✓Experienced Mechanic
Hi there,
If the battery is in good condition, give it a good 1/2 Hr, this should give you enough surface charge to keep you out of trouble, it will take a longer drive to fully re charge the battery, and don't use to many accessories as this will just be a drain as well, so no heater fan, no headlights this will help.
