2002 Toyota Highlander Diagnostics code P1730
32,450 MILES • 6 CYL • 4WD • AUTOMATIC
IAKANI
Wile on motion, my check engine light came on. This affected the smooth changing of gear and also unable to enter higher gears i.e 3,4 and 5.
Used compter diagnostics scanner, showed P1730 as the fault code.
What can i do/change to solve this problem? If it is due to sensor failure, where is it located?
Jul 28, 2008 at 8:43 AM
ONIOLUDAYOADEKUNLE
I have related problem and I use same jeep model. Highlander 2002. Pls what necessary way to solve the problem?
Jan 15, 2013 at 1:29 AM
