Wile on motion, my check engine light came on. This affected the smooth changing of gear and also unable to enter higher gears i.e 3,4 and 5.
Used compter diagnostics scanner, showed P1730 as the fault code.
What can i do/change to solve this problem? If it is due to sensor failure, where is it located?
Jul 28, 2008 at 8:43 AM
