Engine Performance problem
2001 Toyota Highlander 6 cyl Two Wheel Drive Automatic
We had a flood around my area I went threw high water about up to the bottom of my door, my truck ran fine but later in the week I starting hearing sounds like my muffler was going bad when I investigate the problem it was coming from my engine I check the oil and transmission fluid both were ok what can it be?
Sep 24, 2008 at 2:36 AM
