2001 Toyota Highlander Oil disappearing
2001 TOYOTA HIGHLANDER
SDIPPEL
Engine Mechanical problem
2001 Toyota Highlander 6 cyl Automatic 120000 miles
My car needed 3 quarts of oil before I went on a 8oo mile trip. It was filled up, but on the way back it totally ran out of oil on the interstate and stopped. There is no sign of oil leakage anywhere that we can see. Where can it be going and what will this do to the engine?
It also starts shaking between 70 and 77 mph, but stops after you pass that speed. Is this a tire issue?
Dec 18, 2008 at 3:40 AM
DOCFIXIT
  • 18,828 POSTS
Two possibilities rings or valve guides or both. Check tail pipe black sooty stuff that is oil.
Shake tire balance
Dec 18, 2008 at 5:58 AM
