Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Highlander
Tires
Size
2001 Toyota Highlander 2001 Highlander tire question
2001 TOYOTA HIGHLANDER
70,008 MILES • 4 CYL • 2WD • AUTOMATIC
BAMABOY98
MEMBER
1 POST
My highlander needs new tires and i have a set. The orginal size is 225/70/16 and the set i have are 265/75/16 and was wandering if they would fit?
May 27, 2008 at 4:45 AM
DON OLDFORD
MEMBER
The largest you can go on a Highlander is 236/70R/16 or it will rub on the wheel well.
Jun 17, 2008 at 10:08 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
