Clutch pedal goes to the floor
200,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
NARENDRA GOUNDER
When i press the clutch it sticks down the bottom and i cannot change any gears.
I recently changed clutch master cylinder but i can hear some air leaking when i press the clutch.
Toyota Hiace D4D
Mar 31, 2020 at 12:06 PM
  • 110,251 POSTS
Does the fluid in the clutch master cylinder stay full? Did you bleed the system? As far as it staying to the floor, it could be related to air in the system if not bled. The slave could also be bad.
Please let me know if there is any fluid loss and if you bled it.
Mar 31, 2020 at 12:30 PM
