Toyota hiace ac compressor very hot.
10,455 MILES • 4 CYL • 2WD • MANUAL
DEVIABSALOM
  • 6 POSTS
Though the ac system is cooling,the ac compressor pump is very hot!what can cause this?the magnetic clutch is new!the technician has removed the ac compressor,cooler condenser and the cooler evaporator and serviced !the ac pump is still getting very hot!
Jan 30, 2014 at 11:01 PM
MLDANIELS2000
  • 227 POSTS
Lack of oil in system, but by nature it will get hot because it is compressing refrigerant gas which heats up under compression.
Jan 30, 2014 at 11:04 PM
MLDANIELS2000
  • 227 POSTS
What are the system pressures when running and the outside ambient air temperature?
Jan 30, 2014 at 11:05 PM
DEVIABSALOM
  • 6 POSTS
The compressor should be hot when system works but should it be extremely hot?the oil was topped up!
Jan 30, 2014 at 11:16 PM
DEVIABSALOM
  • 6 POSTS
He used 20g Ac oil and 450g R134a gas!system was Serviced using an Ac 930 air conditioning service unit.
Jan 30, 2014 at 11:21 PM
MLDANIELS2000
  • 227 POSTS
How much oil was added?
DEVIABSALOM
  • 6 POSTS
20g and 450g r134a cooler refrigirant gas
Jan 30, 2014 at 11:29 PM
MLDANIELS2000
  • 227 POSTS
Next point is to check pressures then.
Jan 31, 2014 at 7:54 AM
DEVIABSALOM
  • 6 POSTS
What are the recommended pressure for the system to be considered perfectly in good working Oder?what can cause pressure not to be on the correct levels as required and can this be the cause of the cooler compressor pump becoming extremely hot?The cooler compressor pump is in good condition.
Jan 31, 2014 at 9:10 AM
MLDANIELS2000
  • 227 POSTS
Low side 26-34 psi high side 250-275 psi
Jan 31, 2014 at 11:42 AM
DEVIABSALOM
  • 6 POSTS
Low pressure side -34psi and High pressure side-170psi.these are the readings on the pressure test as undertaken by the technician!
Jan 31, 2014 at 5:28 PM
MLDANIELS2000
  • 227 POSTS
Then it should be good. Is the system shutting it down on its own and not cooling?
Feb 1, 2014 at 6:10 AM
MLDANIELS2000
  • 227 POSTS
Plus my earlier post of pressures had a typo. 150- 175 psi high. Yours is within specs.
Feb 1, 2014 at 6:11 AM
