1973 Toyota FJ-40 No brakes
1973 TOYOTA FJ-40
66,000 MILES • 6 CYL • 4WD • MANUAL
HILLTATER
If I press on the pedal just once it will not stop, but, if I pump them about three times it will stop the cruiser and not bleed off. I have 4 wheel drum brakes. I have rebuilt all 8 of my wheel cylinders, replaced the booster and put a new mastercylinder on. None of these have fixed the problem. The only thing left that I can think of is the proportioning valve, could that be the cause?
Dec 21, 2009 at 2:32 PM
  • 31,937 POSTS
Hi there, this sounds like an adjuster problem, go over all the adjusters , do up each until the brake locks up then back it off till the wheel frees up, start here.
mark (mhpautos)
Dec 21, 2009 at 3:40 PM
