1973 Toyota FJ-40 front brake drum
1973 TOYOTA FJ-40
200,000 MILES • V8 • 4WD • AUTOMATIC
DALEBROOKS
my right front brake drum is very tight and hard to take off to get to the brake shoes, can someone tell me how to get the drum off is there a special drum puller ?
Apr 20, 2009 at 11:46 AM
HILLTATER
If you haven't fixed your problem yet, there are 2 brake cylinders per wheel, use a flathead screw driver and loosen the adjusters on the back of the hub. On my cruiser there were two screws holding the drum on on the outside (lug side) of my drum.
Dec 21, 2009 at 2:39 PM
