rear right direction signal
TOYOTA ECHO
PASTOR 6745
the right rear direction light does not light it also is the hazard light. replaced bulb. nothing. has interchagable sockets. tried the left socket. nothing.
appears no power is in the contacts. maybe a ground
wire. problem. everything light works except that one socket. i guess I should check it with a voltage tester
Nov 24, 2007 at 7:02 AM
  • 31,937 POSTS
Hi there,
Make sure you are using the correct globe, double or single filament. Remove the light ass and unplug harness. Check for power in loom, if OK problem is in combo light, if not work back along loom.
Mark (mhpautos)
Nov 24, 2007 at 7:55 AM
