2002 Toyota Echo wont move once in gear
ROSKECJ
Transmission problem
2002 Toyota Echo 4 cyl Manual 85000 miles
when i put my car in gear it does not move anywhere it just sits there reving up.
has my transmission gone bad?
Aug 6, 2008 at 9:08 AM
  • 75,988 POSTS
Check the throttle position and vehicle speed sensors they give the computer the throttle and governor pressures/ inputs then the computer commands the transmission to upshift/downshift/lock-up. etc
Or problem with the transmission range sensor
Sep 19, 2008 at 11:48 PM
