2002 Toyota Echo coolant temperature
60,000 MILES • 4 CYL • FWD • MANUAL
CHARLESDEMERS
The check engine light is on and it tell me that the engine coolant is too cold. The level is OK end it have been change recently. What can i suspect first, the thermostat or the coolant temperature sensor?
May 1, 2008 at 10:37 AM
  • 31,937 POSTS
Hi there,
Replace the thermostat first, and if you still get a code look at the sensor.
mark (mhpautos)
May 1, 2008 at 10:44 AM
