Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Echo
General
2001 Toyota Echo IDLE
2001 TOYOTA ECHO
28,007 MILES • 4 CYL • 2WD • AUTOMATIC
ANGELUZ89
MEMBER
1 POST
WHEN THE CAR IS COLD IT HAS A ROUGH INDLE AND WHEN IT START TO HEAT UP INDLE START TO RUN REALLY HIGH.
Feb 26, 2009 at 7:38 AM
Experienced Mechanic
Check the coolant temperature sensor/idle air control valve/throttle position sensor/PCV and EGR valves
Feb 26, 2009 at 7:54 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
