2001 Toyota Echo fuel pump reset switch
85,000 MILES • 4 CYL • FWD • AUTOMATIC
CRASHANDDASH79
I changed the #3 ignition coil and now the car runs great...for about 5 seconds. It was running with a dead cylinder before I changed it out. Is this a fuel pump issue, or is there another problem? Could I need to reset the fuel pump?
Jan 23, 2010 at 2:42 PM
  • 75,988 POSTS
You don't have a fuel cut off switch its not a ford-try checking the fuel pressure with a fuel pressure gauge designed for your fuel system to rule out the fuel pump
Jan 23, 2010 at 4:09 PM
