2001 Toyota Echo engine heating
SALAHMAX
Engine Cooling problem
2001 Toyota Echo 4 cyl Two Wheel Drive Automatic
Hello ,
this is my firest qustion , when i turn on AC and blower motor speed in ( level 2 ) every think is OK , and my car working good, but when i incrase speed of blower , the hot sign goes on , in the ( level 3 ) speed the hot alert appear after 20 Min , in ( Max speed blower) the alert happen after 10 Min or less , i trying to check the Amp of blower and found in level 3 speed is ( 7.3 AMp ) and in Max speed ( 10.5 Amp)
also i check the resister as like in service manual , the Ohm is good
Pls advice me what's the problem with my car
May 18, 2009 at 11:27 PM
MMPRINCE4000
  • 8,548 POSTS
If you are saying the engine is overheating, check coolant level and make sure the cooling fans are working.
May 18, 2009 at 11:35 PM
SALAHMAX
thank you for your reply
i'm already change the coolant with new one and cooling Fan , all the time i check th coolant level , it's Ok , i checked the old one ( cooling fan ) it's about ( 8 Amp )
note : if i select blower speed for level 2 , the engine never goes hot
May 18, 2009 at 11:52 PM
