Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Echo
Engine Cooling
Cooling Fan
Not Working
2000 Toyota Echo toyota
2000 TOYOTA ECHO
123 MILES • 4 CYL • FWD • AUTOMATIC
TRAVELMAN
MEMBER
1 POST
my idle is high and my cooling system fan is not working
Sep 27, 2009 at 11:13 AM
F4I_GUY
Experienced Mechanic
For the high idle.
Check:
-vacuum leak
-dirty throttle body
-maladjusted idle screw
-Faulty idle air control valve
With regards to the fan, check your fuses first, relay, fan motor and finally temperature sensor.
Oct 7, 2009 at 12:18 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
