2000 Toyota Echo Clutch problem?
2000 TOYOTA ECHO
86,500 MILES • 4 CYL • 2WD • MANUAL
WILLIAMOLSON
I have difficulty moving the gear shif into first gear from neutral at stops. After depressing clutch and finding that moving the grear shifter into first gear is not possible, I must fully release clutch and depress it again in order to move the gear shift.
Sep 24, 2008 at 6:51 AM
Bleed the clutch and adjust for free play and see what happens-
Sep 24, 2008 at 8:31 AM
