2000 Toyota Echo alternator
SJESSEN68
Electrical problem
2000 Toyota Echo 4 cyl Two Wheel Drive Manual
how do I check the alternator
Oct 12, 2009 at 5:03 AM
MMPRINCE4000
  • 8,548 POSTS
Easiest way is to take a DVOM (digital volt/ohm meter) and measure DC volts at battery connections with engine running. Output should be 13.5-14.5V.
Less that 13.0 or greater than 15.0 indicates an alternator problem.
Dec 8, 2009 at 10:02 AM
