1999 Toyota Echo engine check light is on
39,000 MILES • 4 CYL • FWD • AUTOMATIC
ADRIAN85991
hi,
my car has an engine check bulb and it lights up on some occasions for example when going up a hill .
the car has poor accelaration . when i press the gas pedal , the car doesnt respond instanly.
i think it is from the air flow sensor but i need a second opinion from you guys .
thanks for your help, and keep up the good work.
Jul 9, 2010 at 7:44 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 9, 2010 at 8:08 AM
NATHAN300
  • 30 POSTS
i checked and changed all oils and filters fom the car . i just made a service . but the problem still remains ( poor accelaration and engine not responsive and poor idle. the check engine light will light up randomly esspecially when i go up a hill.
my mechanick told me that the problem is probably coming from the air flow sensor , and it needs to be replaced.
what do you think?
thanks again
Jul 9, 2010 at 8:23 AM
  • 75,988 POSTS
If he scanned it for code/s and it came up with the airflow sensor-clean it and see what happens
Jul 9, 2010 at 8:34 AM
NATHAN300
  • 30 POSTS
ok , thanks for your help. great job!
Jul 9, 2010 at 8:38 AM
