1999 Toyota Corolla Brake Light on the dash
100,000 MILES • 4 CYL • FWD • AUTOMATIC
DR A
In the past few months the red brake light on the dash stays light. This is the same light which illuminates when the emergency/parking brake is applied.
What are some of the caused for this light being illuminated on a constant basis?
Jan 30, 2008 at 9:17 AM
MASTERTECHTIM
  • 4,750 POSTS
you are low on brake fluid. check the level in the master cylinder and fill to full mark.
Jan 30, 2008 at 9:18 AM
DR A
I assumed fluid level may be the culprit so I changed out the rear shoes to no avail. Tonight I will change out the badly worn front pads. This should push enough fluid back up into the resevoir to turn out the light. I will keep you informed, Again THank you.
Jan 30, 2008 at 9:29 AM
MASTERTECHTIM
  • 4,750 POSTS
exactly. if the light is still on its because the float is hung up and all you have to do it lightly tap on the master cylinder and the light should go out.
Jan 30, 2008 at 9:56 AM
DR A
[quote:ed67ff4414="mastertechtim"]exactly. if the light is still on its because the float is hung up and all you have to do it lightly tap on the master cylinder and the light should go out.[/quote:ed67ff4414]
Problem Solved.. It was the front pads.. Thank you
Jan 31, 2008 at 3:53 AM
