1993 Toyota Cressida Sticking power window
1993 TOYOTA CRESSIDA
LOOSEDOGG
  • 6 POSTS
Electrical problem
1993 Toyota Cressida 6 cyl Two Wheel Drive Automatic
I own a 1993 Toyota Chaser which had a previous owner. I have been having the problem from I got the car. The driver window goes all the way down but sticks on the way up and it won't move for a couple of minutes. A electrician looked at it once and told me that the motor is ok. He said a little chip that is in the motor keeps overheating and cause the motor to stop. How do I fix this problem
Oct 27, 2010 at 6:55 AM
SATURNTECH9
  • 30,869 POSTS
If that's the case then you will have to replace the motor or motor regulator assembly.
Oct 27, 2010 at 7:10 AM
LOOSEDOGG
  • 6 POSTS
Can I get just the regulator assembly? Because the motor works fine.... it just stops when I try to wind up the window
Oct 27, 2010 at 7:19 AM
SATURNTECH9
  • 30,869 POSTS
Here's the problem if the regulator break's then you can replace the regulator.But if it goes up half way and if it rest's will go up the rest of the way what does that have to do with the regulator?That sound's like a motor to me.Regulator's don't cool down and rest and then work.There mechanical not electrical.Are you sure that you have a 1993 Cressida because i have no listing for that year and model for part's or repair.
Oct 27, 2010 at 7:41 AM
LOOSEDOGG
  • 6 POSTS
I own a 1993 Toyota Chaser..... Its a part of the cressida family
https://images.2carpros.com/forum/automotive_pictures/586914_IMG00077201006201630_1.jpg
Oct 27, 2010 at 7:55 AM
SATURNTECH9
  • 30,869 POSTS
You must live out of the usa i don't have a listing for the chaser for part's or repair there a lot of car model's that are only sold out of the usa and i don't have information on part's or repair for those model's.But it it sound's like you need a new motor for your window.
Oct 27, 2010 at 9:09 AM
LOOSEDOGG
  • 6 POSTS
what is your advice to dimming light? when turn om my indicator the lights in my dash dims in sync with the indicator lights
Oct 27, 2010 at 12:41 PM
SATURNTECH9
  • 30,869 POSTS
So when you have your dash light's on they dim as your turn signal flashes?
Oct 27, 2010 at 1:08 PM
LOOSEDOGG
  • 6 POSTS
yeah......
Oct 28, 2010 at 6:09 AM
SATURNTECH9
  • 30,869 POSTS
A bad ground loose connection loose or corroded battery cable's bad battery or weak charging system.
Oct 28, 2010 at 7:08 AM
