1990 Toyota Cressida
245 MILES • 4 CYL • 2WD • AUTOMATIC
FOX-1
my engine has been over all but it is leaking oil why is that?
Jan 31, 2008 at 6:14 AM
  • 31,937 POSTS
Hi there, depending on where the oil leak is. you may have a faulty seal or the mechanic was not careful enough when doing the repair, i would suggest you return it to the repairer and ask them to investigate the leak, if the engine was repaired recently you should have a warranty on the work done. ask about this first.
Mark (mhpautos)
Mar 5, 2008 at 7:38 PM
