1987 Toyota Cressida
1987 TOYOTA CRESSIDA
SHORTNSASSI2U
HOW DO YOU CHANGE OVER THE A/C FROM R12
Aug 15, 2009 at 2:23 AM
  • 31,937 POSTS
Hi there,
You will have to change the compressor oil, replace the receiver dryer retro fit the new charge points, evacuate the system and make sure that it holds a vacuum and fill with the correct quantity of refrigerant, you will need to check system pressures when done to ensure all is ok.
mark (mhpautos)
Aug 15, 2009 at 2:42 AM
