1986 Toyota Cressida Idle RPM
1986 TOYOTA CRESSIDA
JCAZMAN19
Engine Mechanical problem
1986 Toyota Cressida 6 cyl Two Wheel Drive Automatic
How do you turn UP the idle on an 86 Toyota Cressida so it will sit at 700RPM as opposed to its current setting at 500RPM
Apr 17, 2009 at 11:25 AM
On the throttle body there's a plug for the idle adjustment screw. Before you adjust you need to short T to E-1 on the check connector
Apr 17, 2009 at 11:44 AM
