1984 Toyota Cressida Engine troubleshooting
1984 TOYOTA CRESSIDA
ANGELINCALI
Engine Performance problem
1984 Toyota Cressida Two Wheel Drive Automatic
When leaving a stop sign/light the car sputters and wont go but a few feet. If I pump the pedal as fast as I can it will go if I pause in the position that made it go. It seems like there is a vaccum/electr/ problem. Its kind of like taking the coil wire and removing it and tapping it, the car runs great if I foor it as I'm going on the freeway, but it wont go from a stand still unless i pump the pedal and pause on the position where it would run and not bogg or run sputtering. At idle its fine, but when putting down the pedal it acts funny.
Dec 10, 2009 at 7:04 PM
Check the fuel pressure to rule out the fuel filter and a weak fuel pump-test the TPS and Airflow meter
Dec 10, 2009 at 7:10 PM
ANGELINCALI
what is a tps?
Dec 11, 2009 at 3:02 AM
Throttle Position Sensor
Dec 11, 2009 at 5:19 AM
