1993 Toyota Corona leaking transmission
VIPERADO
Transmission problem
1993 Toyota Corona 4 cyl Front Wheel Drive Automatic
I have a A241E transmission that is spilling all the oil through the overflow hose at the top of the transmission. i tried leading the hose to a small bottle to catch the oil but i realized that the oil starts coming from the kickdown cable where it attaches to the trottle body, what could be causing that problem.
Dec 2, 2008 at 7:09 AM
  • 31,937 POSTS
HI there,
Check that the oil level is not chronically over full, and get a transmission specialist to check and report on this as there will be a few tests that will need to be done to determine the exact cause of this problem.
Mark (mhpautos)
Dec 2, 2008 at 7:18 AM
