1993 Toyota Corona hello
1993 TOYOTA CORONA
ROGER007
  • 38 POSTS
Transmission problem
1993 Toyota Corona 4 cyl Front Wheel Drive Automatic
i have a problem with my car cannot shift always in 3rd gear when i run my car..what is the problem of this matter?please help me!!
Jul 12, 2010 at 6:12 PM
Check and test the TPS and VSS the computer uses their input signals to command and control the operation of the transmission if okay further testing should be done such as transmission pressure tests
Jul 12, 2010 at 8:47 PM
ROGER007
  • 38 POSTS
is there a connection to the transmission if the speedometer is not functioning
Jul 13, 2010 at 2:32 PM
ROGER007
  • 38 POSTS
my speedometer in my dash panel is not functioning is there a connection that's why my transmission is not shifting?
Jul 13, 2010 at 2:43 PM
These 2 sensors I gave you has something to do with the tranny as for your speedometer check the VSS
Jul 13, 2010 at 4:00 PM
