1989 Toyota Corona Both Radiator Fans not working
1989 TOYOTA CORONA
150,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRIS1981
The radiator fan & A/C fan suddenly quit working. Hot wired both fans & they work. Checked relays ( 1 five pin relay & 2 four pin relays ) & fuses, they are fine. My charging indicator on dash board also not working ( always off) . Bulb is fine. Checked connector & no power coming. Pls help me to locate the faulty parts. ( I don't have the manual ). Thx in advance.
Dec 1, 2009 at 3:03 PM
Check and test the coolant temperature sensor and engine temperature gauge switch/sender-both okay think! wiring and computer
Dec 1, 2009 at 5:04 PM
CHRIS1981
Thx again..giv full marks to reply. will chk both sensors. Not sure whether it has a computer. Need help with wiring diagram. It has 5A-F engine ( no EFI). Thx in advance.
Dec 2, 2009 at 8:51 PM
