1980 Toyota Corona BRAKE LIGHTS NOT WORKING
1980 TOYOTA CORONA
JEANNETTE.ROOKS
Brakes problem
1980 Toyota Corona Two Wheel Drive Automatic
MY 1980 TOYOTA CORONA BRAKE LIGHTS WANT WORK. THE BLINKERS,BACK UP, PARKING ETC. ALL WORK. IS THERE A BRAKE FUSE? IF SO WHERE IS IT LOCATED? I REPLACE THE BRAKE LIGHT BULBS.
Mar 8, 2010 at 11:36 AM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
will need test fuses with meter. these models have two fuse blocks. One is located behind a panel in the dash, while the other can be found on the left front fender apron. if fuses are good then check the brake light switch near the brake pedal
Mar 8, 2010 at 11:39 AM
