1995 Toyota Corolla Steering Wheel Shake
MCHGNER
I have a '95 toyota corolla, about 145,000 miles, 1.6L engine. When I drive at speeds above 10 mph, the steering wheel shakes back and forth, it's not a huge oscillation but I can feel it in the entire car. I know that I have two bent rims on the rear axle. But I have been told that bent rims on the back will not affect the steering wheel. Would buying new rims for the back fix this problem?
Jul 28, 2007 at 2:46 PM
  • 31,937 POSTS
Hi there,
Best have the steering checked for worn tie rod ends or balljoints, more than likley it's a tyre or rim fault so have them checked as well.
Mark (mhpautos)
Jul 31, 2007 at 5:11 PM
Suggested Repair
Have the steering inspected for worn tie rod ends or ball joints, and have the tires and rims checked, since a tire or rim fault is the more likely cause.
Conversation Summary
The owner of a 1995 Toyota Corolla reports steering-wheel shake and vibration throughout the car above 10 mph, and asks whether replacing two bent rear rims would fix it. The expert recommends checking the steering for worn tie rod ends or ball joints and also inspecting the tires and rims, noting a tire or rim fault is more likely.
