Hi there,
This is a very comon problem, the oil is coming from the spark plug tube, these are threaded into the cylinder head and can start to leak with age. To fix you have to remove the rocker cover and tighten the tubes (best to remove and re seal the threads.) As these tubes can be damaged easly best leave to a work shop to do this job. As for the fuel leak check fuel filter & hose to fuel rail a leak should be easy to see.
Mark (mhpautos)
SPONSORED LINKS
Wednesday, August 1st, 2007 AT 12:28 AM
