Toyota Corolla SE 2004, 2 wheel drive
MARTI WALKER
This past Monday, my car was in the shop for new brake pads and checking the rotors. It was not making any noise at that time. Since the brake pads were replaced and the rotors were turned, the right front wheel has been making a "clacking sound" when I press the brake pedal, as I am slowing down. It seems even louder when I'm going down hill, as I'm braking.
My husband took the car back to the repair shop today, and they claimed it was a loose wheel cover; however, re-fitting the wheel cover did not solve the problem because it is still making the clacking sound when the brake pedal is pressed and the car is slowing. What is wrong?
Thank you!
Sep 14, 2007 at 6:06 PM
BMRFIXIT
  • 19,053 POSTS
hi
Its’ the responsibility of the repair shop that did the work
to find out the noise let them take the car for a road test with you
to duplicate the noise
and I think they will find that one of the brake pads is missing a shim
or loose in place
good luck
Sep 14, 2007 at 9:20 PM
