toyota corolla
TOYOTA COROLLA
PETERBI
how to remove door crank(from door panel)
Nov 18, 2007 at 4:51 PM
FISHERMAN
  • CAR REPAIR CONTRIBUTOR
  • 937 POSTS
[quote:2fe3ec8d23="peterbi"]how to remove door crank(from door panel)[/quote:2fe3ec8d23]
Hello!!
the crank uses a "c" clip (Omega style)..
to remove it "push" the panel and use an small wire with a tiny hook in between the panel and the crank and pull it, or use a flat piece of plastic (to avoid damage to the panel) and Push it its not that hard to remove, but you have to see it!
good Luck!
Nov 18, 2007 at 7:57 PM
