Toyota 98 Malfunction Indicator Ligt
JADAM
I drive a 98 Toyota Corolla. Has around 91k miles on it. It drives very well. However, today while slowing down on a ramp before entering the Highway i noticed that the engine malfunction indicator light came on for about a minute or so. I drove for another half an hour after that and did not notice the light again. Could this be indicative of anything? Should I wait for some more time before I take it to a mechanic? if i do take it to a mehanic, should i ask him to perform some specific tests?
Also, on another issue, the last time I had my car checked a few months back, I had asked the mechanic whether my car has a timing belt and should I change it and he had mentioned that my car (98, Corlloa) has a timing chain and that lasts a lifetime and that i should not change it. is this correct?
Will really appreciate your answer.
Thanks
Mar 9, 2006 at 4:28 PM
  • 55,540 POSTS
First thing you ned to do is scan the PCM for trouble codes, then replace failed sensor and recheck, clear codes to recheck. [url]www.eautoelectronics.com[/url]... yes it does have a timing chain.
Mar 10, 2006 at 10:08 AM
