2003 Toyota Corolla Idle Temp Rise
CONCERNEDDRIVER
I have a 2003 Toyota Corolla SE with about 56,000 miles on it. Sometimes when the car is sitting still either in drive or park the temperature rises, but doesn't go into the red. Usually when I start moving it goes down to normal range again. Sometimes I can turn on the AC while I am still sitting still and the temperature also goes down. While I am driving it I haven't had the problem occur. This issue doesn't happen all the time, only once in awhile.
What type of problem could this be? Any help would be really appreciated.
May 17, 2007 at 1:58 AM
  • 75,988 POSTS
[quote:6321fcd562="concerneddriver"]I have a 2003 Toyota Corolla SE with about 56,000 miles on it. Sometimes when the car is sitting still either in drive or park the temperature rises, but doesn't go into the red. Usually when I start moving it goes down to normal range again. Sometimes I can turn on the AC while I am still sitting still and the temperature also goes down. While I am driving it I haven't had the problem occur. This issue doesn't happen all the time, only once in awhile.
What type of problem could this be? Any help would be really appreciated.[/quote:6321fcd562]
Check your coolant level and replace the thermostat for a start.
May 17, 2007 at 10:40 AM
Suggested Repair
Check the coolant level and replace the thermostat as a first step.
Conversation Summary
The owner of a 2003 Toyota Corolla SE with about 56,000 miles reports that the temperature sometimes rises while sitting still in drive or park, but does not enter the red zone. It usually returns to normal when the car starts moving, and turning on the AC while stopped can also bring it down. The issue does not occur while driving and happens only occasionally. The expert recommends checking the coolant level and replacing the thermostat to start.
