Rough ride in low gears
CRONOLLYV
I recently purchase a 1998 Toyota Corolla with 80,000 miles. I changed the air filters, oil filters and spark plugs. Since then I have noticed that it can be a bit rough when taking off in the low gears. The car will shudder violently.
Jan 8, 2007 at 2:53 AM
BACKYARDMECHANIC
  • 337 POSTS
If the problem appeared after you did the work make sure you did not cross the spark plug wires and the are on tight.
Jan 8, 2007 at 5:46 AM
2CARPRO JACK
  • 11,533 POSTS
Also be sure to use OEM parts, Cheaper is exactly that
Jan 8, 2007 at 9:23 AM
