1993 Toyota Corolla Engine Swap
93TOYCOROLLA
1993 toyota Corolla wagon, 270,000 miles, automatic.
Running rough and using oil. Mechanic said it has bad compression on one valve and suggested I replace it with an engine from Japan, which he said they replace at 40K. Is that true, and if so, why? At $1500-1800, would this be a reasonable thing to do?
May 31, 2007 at 4:15 PM
2CARPRO JACK
  • 11,533 POSTS
Common in Japan. Emissions thing, they dont work on anything, just replace it. Be careful though, there sometimes are very minor differences in the Japanese and American engines that can be a pain when swapping over. In general they are a good, cheap way to go
Jun 1, 2007 at 12:50 AM
Suggested Repair
A Japanese replacement engine can be a good, inexpensive option because early replacement is common there for emissions reasons. Before buying, verify compatibility, since minor differences from the US engine can complicate the swap.
Conversation Summary
The owner of a 1993 Toyota Corolla wagon with 270,000 miles reports rough running and oil use. A mechanic found poor compression on one valve and recommended a Japanese replacement engine for $1,500 to $1,800, saying Japanese engines are replaced around 40,000 miles. The expert says early replacement is common in Japan because of emissions practices and that these engines are generally a good, cheap option, but minor differences from American engines can make the swap difficult.
